hill descent control cluster area blanks
Old Dec 27, 2014 | 08:19 AM
TRIARII's Avatar
Default hill descent control cluster area blanks
Special thanks to everyone on the forum and in particular Abran for helping me with my 40" roof mounted LED light bar. It works as it should. Next on my list is a smaller LED light for the rear of the truck. I will mount it using the existing mounting hole provided on the back of the SD roof rack on the passenger side. I want to be able to press a button once to turn on the light and use it as a work light or to assist me while reversing, then I want to be able to press the button again and have it turn off. I dont have anymore room on the speedo bezel cluster so Im looking at the small cluster of buttons near the ashtray on the driver side. The cluster currently has a HDC button and 2 buttons for heated front and rear windshields. There are at least 2 blanks so I want to utilize that space for the wiring.
That buttons and relays should I buy? Do any of those buttons have the click engage feature like the cruise control switch?
Old Dec 27, 2014 | 10:49 AM
cosmiccharlie's Avatar
You can use a cruise control switch with one of the square blank covers. I have a couple already made up if you would like to buy one. I use one for my work light also. I'll be back home Monday or Tuesday and can send you some pictures.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
gamecockdisco
Jul 12, 2010 08:34 AM
Edward Perera
Freelander
Mar 12, 2008 07:04 AM
blackrover
Aug 20, 2007 06:40 PM
Sean 1313
Aug 30, 2005 10:00 PM
