Hill Descent Control...what do I do
Old Mar 4, 2009 | 12:17 AM
guywithadisco's Avatar
Default Hill Descent Control...what do I do
I am still getting to know my disco, I have only had it for a couple weeks now. I just found out about the hill descent control, I was going to try it out but nothing happened. I turned it on then started down the hill and nothing. I do not have the owners manual so I have no idea if there is something special I need to do first. Any help would be great, thanks
Old Mar 4, 2009 | 12:19 AM
Also I dont know if it has anything to do with it, but soon as I turn it on the car starts beeping at me. Thanks
Old Mar 4, 2009 | 01:25 AM
llesra's Avatar
you have to be in low range and in first gear to use hdc
Old Mar 4, 2009 | 07:18 AM
Disco Fuego's Avatar
I freaked out the first time I tried it. Beside my car picking up more and more speed NOTHING happened
Like Arsell already said, you have to be in Lo gear. To get into Lo gear, put your car in neutral (don't be driving more than about 3 mph) and shift the gear from Hi to N then to Lo. It should be relatively smooth, don't try to force it. While the gear selector is in N, you will see a blinking light on the panel and you should hear an audible sound.
The HDC uses the TC and ABS systems if I am not mistaken, and my car makes a lot of noise when it is functioning. I believe that is normal...
Someone correct me if I am wring on any of the above... Also, i have a 2000, and am not sure if the procedure may be diffferent for other years.
Old Mar 4, 2009 | 08:09 AM
jycsalas's Avatar
From owners manual...
Attached Thumbnails Hill Descent Control...what do I do-hdc1.jpg   Hill Descent Control...what do I do-hdc2.jpg
Old Mar 4, 2009 | 08:47 AM
As mentioned, your t/case must be in low range and depending on which gear you have your tranny will determine how much the system will slow you down, 1st gear will be the slowest, drive the less slow.
Old Mar 4, 2009 | 03:09 PM
mwindth's Avatar
Here is a link for an on-line owners manual: http://landroverresource.com/
Old Mar 4, 2009 | 09:44 PM
thanks for all the help, it works great. Thanks for the link to the manual to.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
gamecockdisco
Jul 12, 2010 08:34 AM
Edward Perera
Freelander
Mar 12, 2008 07:04 AM
blackrover
Aug 20, 2007 06:40 PM
Sean 1313
Aug 30, 2005 10:00 PM
