View Poll Results: Should Brendon replace the HG himself?
Absolutely not, he is inexperienced.
![](https://landroverforums.com/forum/images/kirsch/polls/bar2-l.gif)
![](https://landroverforums.com/forum/images/kirsch/polls/bar2.gif)
![](https://landroverforums.com/forum/images/kirsch/polls/bar2-r.gif)
![](https://landroverforums.com/forum/clear.gif)
12.50%
Sure, he has support if he needs and will update us during the process.
![](https://landroverforums.com/forum/images/kirsch/polls/bar3-l.gif)
![](https://landroverforums.com/forum/images/kirsch/polls/bar3.gif)
![](https://landroverforums.com/forum/images/kirsch/polls/bar3-r.gif)
87.50%
Voters: 8. You may not vote on this poll
Hilma - Head Gasket Replacement
#22
It took a call to my mobile mechanic who got it off in a few seconds with a big milwaukee impact and the right sockets. Lifted the body a little and jiggled the sump out!
It looks pretty good, I'll post photos later.
Thanks for the advice Sixpack & Friday Night Disco- I have removed the 3 nuts on the exhaust and only one stud came out. I did not try and remove the others yet. Crossmember is removed too.
Next step, the front cover. I can get off my back for a little bit at least now.
#23
Brendon H (12-27-2019)
#24
I am having to do a head gasket job on one of mine- broke my old record for disassembly today - 2 1/2 hrs to heads off and everything in the parts washer. Helps that I was the last one in this engine. Will be interesting to see how long it takes me for re-assembly. My previous best was 8 hrs going back, but this should be faster because I should not have to tap all the bolt holes since I did it on this one last time.
Weird thing about this one - wife started it one morning and it was missing bad on cyl. 7 and pouring white smoke. Confirmed with a cooling system pressure test, leaked so bad hydrolocked that cyl (pulled the plug to vent). Gasket shows no obvious blown section. I guess I will pressure test the block, but there was no overheat situation on this iteration of the head gaskets and cooling system was full on the morning she had the problem.
Brendon H (12-30-2019)
#25
Heck, might just be a loose head bolt.
#26
I wish that I had dremmelled mine out to match those lines. Free power to port your exhaust that way.
#27
So it took a call to my mobile mechanic friend and his impact gun got that last bolt off no problem.
Went and dropped the oil sump then the front cover. I've been cleaning and cleaning and cleaning.
I'm stuck now on the oil filter head, i was able to remove the 4 bolts but it just spins and doesn't make any progress towards coming off. Anyone take this off and have some advice>?
#28
