Hinge back door
Old Jan 22, 2009 | 06:07 AM
DiscoRom's Avatar
Default Hinge back door
The pin in the upper back door hinge is broken.
Is there any DIY fix to this?
Old Jan 22, 2009 | 06:53 AM
Rover Curious's Avatar
Default RE: Hinge back door
I'm not a fountain of knowledge by any means, but it looks like the hinges are just simply bolted to the door. You should be able to unbolt the entire hinge and replace it with a new one.
Old Jan 22, 2009 | 07:33 AM
unimoged's Avatar
I agree with Rover Curious and I would replace both hinges, upper and lower due to the stress placed on the lower hinge after opening such a heavy door with spare tire to boot.
You would have to spray paint the hinges prior to mounting them. I have had good luck getting an exact match paint in a 12 ounce spray can from carquest parts stores (You just give them your paint code and they will make a can for it). Not sure if you have them in your area.
Old Jan 22, 2009 | 10:06 AM
DiscoRom's Avatar
Thanks guys.
Unimoged, do you know the code or at least a link where I can find the paint code for alpine white?
GramlingMan
May 10, 2013 09:57 PM
PIROLOGISTS
Feb 21, 2012 09:33 PM
LeakyDisco
Feb 16, 2011 11:09 PM
ehill03
Sep 6, 2010 08:15 PM
ajh
Aug 26, 2007 02:42 PM
