Valve Sticking??
Old Jan 20, 2009 | 05:45 PM
sdsilvere38's Avatar
Default Valve Sticking??
Well, just got back from the Rover Indy and he said that all cylinders are getting perfect compression but the #5 cylinder is putting a little bit of oil on the plug causing a misfire. He said it could be a valve sticking. Can this be fixed without a rebuild? Will the ATF "oil" change clear this up?
Old Jan 20, 2009 | 06:31 PM
Default RE: Valve Sticking??
Well if a valve is sticking then you would have lower compression on that cylinder than the others.
Oil on the plug will not cause a mis fire.
Lets start over...why was it in the shop?
Old Jan 20, 2009 | 06:35 PM
ryanD2's Avatar
have them do a cylinder leak down test as well.
Old Jan 20, 2009 | 06:42 PM
It had a tiny bit lower compression in #5but not bad at all. It was in the shop to diagnose my CEL.
Old Jan 20, 2009 | 06:49 PM
unimoged's Avatar
Can you share the Disco's age and mileage and how much oil do you add between changes, etc. does it smoke at startup for few seconds, etc.
A temporary quick fix that may work will be a spark plug with a higher heat range,but this may cause pre-ignition in the specific cylinder. That is if the existing spark plug is oily when you take it out.
Old Jan 20, 2009 | 06:52 PM
It is a 96 Disco with 119,xxx miles. I add about 3/4 of a quart at the most between oil changes.
Old Jan 20, 2009 | 06:53 PM
ryanD2's Avatar
they should have then done a leakdown test, my guess that cylinder is pulling a tad of oil past the rings. too little compression can cause a misfire, but unlikely unless its down to like 80 or less psi.
Old Jan 20, 2009 | 07:07 PM
When was the last time it had a tune up?
What plug wires did you use?
Old Jan 20, 2009 | 07:24 PM
EVN137's Avatar
Oil deposits could be caused by your valve seals also, specially on the intake valve side ( oil gets drawn in during intake coz of the negative pressure ). One tell tale sign of this is when you do a valve job, pay attention to the deposit on the intake valve ( larger in dia vs. exhaust valve ). More often than not, the deposit is on the intake valve. Given the mileage on the engine if you haven't had a valve job yet.....
Misfires could be from alot of things, old plugs, faulty plug wires ( cracked, high resistance, shorting ) coolant leaking into cylinder, bad fuel etc. Need more info like diagnostic codes, etc.
Ed
Old Jan 20, 2009 | 07:28 PM
I had a tuneup 4 months ago. Put magnacore wires on for ****s and giggles 2 days ago and it ran the same.
