Hissing Doors? This might work
Old Mar 9, 2022 | 07:57 PM
cvhyatt's Avatar
Default Hissing Doors? This might work
Getting ready to take a big trip out west and one of the things that has irked me about highway speeds is that my doors (or maybe my windows) leak air a highway speeds. As a result, there's an hissing sound from my doors. I poked around a bit and found the weatherstripping loose and the glue that held them in was dry rotted. I checked all of them and they were all the same way - simple tug and the seal came out.
Not sure is this seal is leaking or maybe its the windows but I thought I would go ahead and seal them up with some black flexshot and push them back in place. Just thought I'd share with folks in case they have a similar issue. Will let you know how it works.
Old Mar 10, 2022 | 08:40 AM
Rackolamb1's Avatar
I had a similar noise and for me it was my rear door window channel seal. It would slide down a few inches and I'd get a ton of wind noise coming in. I could pull it up and it would be fine for a while but would eventually slide back down. I finally put some silicone similar to what you are doing to hold the seal in place. Seems to have fixed the issue for me.
Old Mar 10, 2022 | 10:25 AM
oaty's Avatar
Thanks for the info. I have the same issue. My 2000 D2 back driver door has a draft while driving on the interstate. I only have a 10 min ride but its drafty in the winter.
SSchultz
May 2, 2020 08:42 PM
taylor15
May 5, 2014 09:27 PM
humroot
Jun 21, 2012 10:51 AM
Scott R
Nov 22, 2009 01:22 PM
jwood700
Nov 17, 2009 01:17 AM
