hood latch cable adjustment or new?
99 Discovery 2 115k miles. Hood wont open so suspecting a stretched cable or something like that Ipopped the cable out from the interior release handle and pulled xtra hard with a pair of pliers and walla- hood opened.
Reading the forums I now understand it can be done from the outside as well, through the grill with a pair of long needle-nose pliers. Where is the cable exposed through the grill? Also, what a bummer as this seems to bea security concern. Will the factory alarm trigger if the hood is opened from the outside?
Will I need a new cable and other parts, or can the cable simply be re-adjusted? What should an independent mechanic charge or can a novice mechanic do this themselves?
RE: hood latch cable adjustment or new?
I was hoping there might be a poss. simple solution like simply lubing the cable. I'll try that. Can anyone answer my security concern question- that is can the hood release cable really be accesed thru the grill and will this bypass the factory alarm?
steveo2000
09-08-2015 08:00 AM
