Hood liner / Insulation question
Old Jun 25, 2018 | 09:03 PM
Saturnine's Avatar
Default Hood liner / Insulation question
Right.
So, the under hood pad / insulation thing on MagPie is filthy and horrid -- is this something that can be cleaned or washed? Or just straight up removed and replaced with some other kind of thermal barrier?
You can kinda see all the mud etc in this pic, but it is quite a mess.
Old Jun 25, 2018 | 09:13 PM
shanechevelle's Avatar
Maybe spray it gently with a soap and water mix?
Is that dexcool???
Old Jun 25, 2018 | 10:20 PM
Saturnine's Avatar
Thats what i was thinking..
That pic was when i went to check out MagPie initially -- that was the dex
Old Jun 26, 2018 | 08:08 AM
Sixpack577's Avatar
Someone here used radiant barrier(foil bubble wrap style), and it looked very good.
I would think it would cause the engine bay, and therefore the operating temps to rise.
However, the owner(can't remember their screen name, but I think it was a silver D2 with beadlock wheels) said there was no difference in temperature.
I don't know, but something to consider.
Old Jun 26, 2018 | 08:17 AM
CollieRover's Avatar
I have insulation on the underside of my hood. I have noticed no increase in engine temp afterwards.
The stuff I used really cut down on noise. It is noticeably quieter. You can see it in this photo.
Are the temps in the engine compartment higher? I don't know, but I doubt it.
Old Jun 26, 2018 | 09:06 AM
I wonder what a vent or scoop would do for engine temps. I would love to add a hood scoop with forced air....
Old Jun 26, 2018 | 09:23 AM
Fast951's Avatar
The under hood material is more than insulation, it is also a fire blanket. The plastic buttons that hold it to the underside of the hood are designed to melt away quickly in the case of an engine fire and allow the material to drop down to hopefully snuff the flames.
Be careful not to circumvent a factory safety measure when working in this area.
Old Jun 26, 2018 | 09:32 AM
Sixpack577's Avatar
With vacuum to open and close it.
Ok, now get to it, we need a working model, lol.
Old Jun 26, 2018 | 09:34 AM
Sixpack577's Avatar
[QUOTE=CollieRover;652615]I have insulation on the underside of my hood. I have noticed no increase in engine temp afterwards.
What exact material did you use?
You guys and your ideas...you cost me way too much money, lol
Old Jun 26, 2018 | 09:54 AM
[QUOTE=Sixpack577;652624]
it has been too long for me to remember. Search Summit Racing, JEGS etc. and you will find some. I used a high temp adhesive and aluminum tape for the edges.
took the hood off, and had it upside down on my table. You’ll have to cut a few holes, like where the trim plugs go, and where the radiator cap is.
Take your time prefitting and use weights of some sort to get iit in place. I sprayed adhesive first on hood then on material.
