Hoping for some honest advice
Old Nov 2, 2015 | 05:11 PM
zeroone's Avatar
Default Yahtzee
Here it is.... removed the ALT bracket and this is what I see. Drivers side stopped leaking immediately so no I criminality evidence for that.
As far as the getting hot issue, after rethink king it I have no clue.
Old Nov 3, 2015 | 06:39 AM
drowssap's Avatar
yup that would be leaking and causing you to over heat, they probably didnt clean it well enough when the slapped the new one in.
looks like there is room to change that freeze plug in place though, it would save you a lot of time and work
Old Nov 3, 2015 | 07:26 AM
zeroone's Avatar
Room is plenty.
Let me ask you this... is it worth it to bring it to the shops attention, see if they will repair it, or am I better off just installing a new plug and hoping they didn't cracked the head when the chiseled out the original plug?
Old Nov 3, 2015 | 07:35 AM
drowssap's Avatar
I've never personally seen a head that was cracked replace a freeze plug.
I would replace the freeze plug in place before removing the top end again.
clean the opening a little black RTV and tap the new one in,
let it dry and pressure test it before you put it back together.
JMHO
Old Nov 3, 2015 | 08:52 AM
zeroone's Avatar
Thanks for that drowssap, I did just get off the phone with Headmasters... he is willing to repair it. However, he does NOT want me to take it apart. He must know I will require he supply gaskets and bolts. I'm currently calling around looking for a tow at his request. Problem is, it's a 40 minute drive from where the D2 is sitting. At best... I would like the shop to split the cost of the tow. I think I'm being reasonable.
I did laugh a bit with him.. he understands. So far... I'm not blowing my top.
Old Nov 3, 2015 | 09:44 AM
drowssap's Avatar
honestly I would think he should be paying the whole tow, good luck
Old Nov 3, 2015 | 10:24 AM
zeroone's Avatar
That's what I'm shooting for.
Old Nov 9, 2015 | 10:18 AM
zeroone's Avatar
Little update for anyone following,
Saturday AAA towed the D2 down to Saddleback for free, thanks to my wonderful mother-in-law. Left it with them, got compliments on how good it sounds and runs. Hopefully I get it back in the same condition I left it, sans the leaky freeze plugs.
Old Nov 10, 2015 | 06:12 PM
dr. mordo's Avatar
Good luck. It definitely sucks when you complete a huge job and run into a major problem.
Just one more reason to use ARP studs, though.
Old Nov 14, 2015 | 01:52 PM
zeroone's Avatar
Thought about it to be honest. Just didn't feel like dropping the coin on ARP.
I did call the shop today. They told me the new freeze plugs are in, but there is another leak. They are apparently going to repair it and let me know when it's done. Shop owner seems to be holding up his end of the deal. Says he won't let me take it home if it's leaking.
So far feeling better about having them reman the heads for me.
