Horn fuse out again
Old Jun 9, 2010 | 04:50 PM
Antmen's Avatar
Default Horn fuse out again
When i first bought the truck (going on two months or so now,) the horn wasn't working. I replaced the fuse (under the hood) and all was good.
Was driving on the FDR (a moving, dangerous parking lot of a highway in Manhattan) and held down the horn for about 2 seconds for an idiot that decided to jump in at the last minute. Stopped working.
Fuse blown. Don't want to replace it because obviously something is wrong there. Any diagnosis steps for this? I don't just want to throw a new horn set at the problem.
I'm about to look at the RAVE manual, but wanted to know if anyone else has troubleshot this?
-Anthony
Old Jun 9, 2010 | 06:16 PM
okdiscoguy's Avatar
I replaced my horns with a set from Hella. Same problem. Adding a relay cured the problem. You could add another relay to the circuit if you want.
Old Jun 9, 2010 | 07:13 PM
lipadj46's Avatar
replace your horn, a used set will cost $20 or so, the relay could be bad also.
Old Jun 9, 2010 | 07:15 PM
Rovin4life's Avatar
horn buttons are bad, just get a new set.
Old Jun 11, 2010 | 08:24 AM
Antmen's Avatar
I was trying to avoid simply replacing the horn and then, possibly, the buttons if something else is causing it. I would've sworn I read on here somewhere about jumping the relay or other point in the circuit to test/diagnose.
I guess the cost is so low replacing the horn set isn't a big deal (and looks like a simple bolt on/off swap.)
-Anthony
Old Jun 12, 2010 | 10:53 AM
Rovin4life's Avatar
horn buttons cause the issue more then the horns themselves. Besides if you suspect the horn yes you can jump the relay but it won't reveal which one is bad.
if you want since it doesn't always blow run two inline fuses in both of them.
you will know one is blown by the noise it makes. Plus it the main one blows again it will be the switch.
Old Jun 17, 2010 | 10:50 AM
Carl082974's Avatar
I bet your cruise control also stops working, this seems to happen when the horn stops working
Old Jun 17, 2010 | 12:55 PM
lipadj46's Avatar
Because they are on the same fuse.
Old Jun 17, 2010 | 04:07 PM
Antmen's Avatar
Yup - I assumed they were on the same circuit because there's only one fuse out and all of my vacuum hoses are good.
Antmen
Feb 17, 2023 05:15 PM
DiscoRover007
Sep 2, 2014 04:49 PM
bcolins
Nov 15, 2011 08:57 AM
lipadj46
Aug 13, 2009 07:47 PM
johnkbl
Dec 29, 2008 11:15 AM
