Horn honk with remote door lock
I know if a door is not fully closed, the horn will honk to alert to the ajar door when trying to set the alarm. But it seems my horn is honking every time now that I remote lock it. I've checked the doors. They all seem closed even the back. Did I hit something by accident to set it so it honks? Can I turn it off? The only thing I can think is the door lock actuator on the rear driver side isn't working so I need to pull the inside handle to unlock that door.
Thanks!
Thanks!
By thanks guys...
It stopped doing it, after I changed the oil... So it's probably the switch on the hood. I did notice the rubber around the switch was a bit torn so it's probably shorting or something
Thanks again
Thanks again
totalperformance65
May 21, 2006 03:09 PM
