Remote Door Lock Range
Old May 19, 2006 | 05:50 PM
totalperformance65's Avatar
4th Gear
Default Remote Door Lock Range
Is it me, or is the range on the key remote terrible? I have a 97 Range Rover 4.6 HSE, and I have to be about 2' from the car before it will unlock the doors. I've already replaced the batteries twice, with no improvement. Shouldn't I be able to be a fair distance away and it still work? I checked the power going to the RF receiver, and it's getting it. Is there an aftermarket receiver or some sort of other fix to increase the range? Thanks for your time.
Old May 19, 2006 | 06:11 PM
4x4guy's Avatar
Default RE: Remote Door Lock Range
Do you have after market window tints? some of them contain metal fragments that shield the signal,also do you live or have an aerial mast close by,this can confuse the system,lastly the fobs dont like having a bunch of other keys with them as these remotes also suffer from electrostatic interference caused by the other keys,best of luck Paul UK.
Old May 19, 2006 | 07:25 PM
4th Gear
I do have tinted windows. However, I don't know if they're aftermarket or not (not a RR stock expert). I do not live next to any large ariels nor do I have any aftermarket antennas on the vehicle. I only have 2 or 3 other keys on my keyring, but i'll try pulling it off and using it separately. Thanks for your input.
Old May 19, 2006 | 08:01 PM
Try using your remote from different angles and heights.
Mike
Old May 21, 2006 | 03:09 PM
moneypit37's Avatar
This may sound weird, but I had a car where the remotes started loosing range. Try touching the remote to your chin while you test it. My distance went from about 2' to about 30', but I have a lot of metal in my mouth.
jfall
May 11, 2017 11:37 PM
KAR 120C
Jul 13, 2015 12:41 PM
jsaenz
Dec 30, 2013 03:28 PM
A5scott
Aug 25, 2012 08:30 PM
larsen09
Feb 21, 2012 07:11 PM
