Horriable shake When in Gear
Old Mar 27, 2008 | 02:14 PM
cgullett's Avatar
4th Gear
Default Horriable shake When in Gear
Hello everyone! My name is Caleb, and I have been an avid reader of This forum since the purchase of my 02 Disco II, 2 years ago. I have never posted before, because my baby ran good, and there are a lot more people on here that know way more than I do.
Anyways here is my problem. About 2 months ago I threw a code, and it turned out to be a misfire of two cylinders (4+8 I think), anyways I ran some fuel injector cleaner through my system, and cleared the codes, and she was running fine.
About two days ago, I started her up and backed out of my driveway and hear a huge “CLUNK”. I didn't think much of it, maybe I hit a cat or something. Well I put it in drive and the whole car started shaking. The Disco Shook very bad until I hit about 200 RPM and it shifted to second. After I speed up the shaking goes away, but there is a horrible ticking sound. I hear it the best when I'm driving next to a concrete separator. I hear this high tick when I press on the gas. I've dropped it into neutral going onto an off ramp and the car runs like it should. Also in Neutral, I can rev her up, and she runs like she should, no knock, no shake, nothing. Its only when I go into gear.
I've searched through some posts, and seen that maybe the drivetrain is having problems, but it almost sounds like a tranny issue to me. Do you guys have any idea where i should start looking. I've got new plugs to put in, but I really don't think that is going to fix this issue.
The shake is so bad, it knocked my GPS off my dash.
Oh yeah, if I slow down to first gear (like at a stoplight) and accelerate, the shake comes back.
Thanks for taking the time to look at this, and any help would greatly be appreciated.
Caleb
Old Mar 27, 2008 | 06:06 PM
Default RE: Horriable shake When in Gear
Take it to a drivetrain shop today!!! It could be your double-cardon joint going bad, when it breaks it puts a hole the size of your fist in the side of your transmission, $7,000 repair.
Fix it before it breaks, $200 repair.
Not having your trk shake when you drive, priceless.
Old Mar 27, 2008 | 06:15 PM
geotrash's Avatar
Stop driving it now!!! Don't move it another inch until you can crawl underneath and check the front driveshaft. If it has never been replaced, the U-joints or double cardon joint are probablyabout to go. If they do when you're driving, it'll knock a hole in your transmission that'll cost several thousand to fix.
Dave
Old Mar 27, 2008 | 06:53 PM
cgullett's Avatar
4th Gear
I was talking to a local landy owner, and he said it might be the u joint. I have noticed it started pulling to the right side a couple of weeks ago. And I checked my tire pressure and that was good. Just for an Idea, does anybody know how much a double-cardon joint or u-joint replacement cost?
Old Mar 27, 2008 | 09:37 PM
okdiscoguy's Avatar
$200 and have it towed there. If it breaks, you are looking at $7K to replace the transmission and possibly the transfer case....
Again, do not drive it anymore.
Old Mar 28, 2008 | 08:59 AM
ORIGINAL: cgullett
U-joints will not cause a vehicle to pull one direction. Might want to check for a tire with separated tread, an alignment issue or a brake caliper that is stuck.
Old Mar 28, 2008 | 05:37 PM
khuds308's Avatar
a co-worker wants me to buy his Disco I with this same issue. I have not seen the thing yet so i don't have a clue, but is this a problem for the D I's or just D II's.
Old Mar 28, 2008 | 05:48 PM
ORIGINAL: khuds308
The double-cardon issue is only with DII's.
Take your co-workers trk to a mechanic and have it looked at before you even thing about buying.
jeffh
Jan 20, 2011 12:35 PM
jaybe_2
Aug 7, 2006 12:26 AM
614buxnut
May 18, 2006 03:24 PM
mcclellandm
Nov 26, 2005 04:54 PM
wax
Nov 20, 2004 05:32 PM
