Hose-clip tool?
Hose-clip tool?
What kind of tool is used to install the Land Rover factory installed hose-clips?
I always replace them with whatever is readily available at the local parts store because I can't figure out how to reuse them etc.
I can see how they are handy for tight spots etc... I replaced a large one with a screw/worm drive hose clamp and the screw is about a 1/4 inch from the serpentine belt etc.
I found the part number for the hose-clip that secures the low pressure PAS hose to the PAS reservoir: QYC100240
I also uploaded a pic of one I removed.
Does anyone what type of tool is used for these types of hose clips?
Cheers,
Thomas
Cheers,
Thomas
https://www.google.fr/webhp?sourceid...enters+pincers
Does that tool nip up the factory fitted style clamps the OP is talking about? I can see how it would hold open the t stat style clamps, which I've always done with mole grips. I agree that will be great for that type of clamp in hard places, but not sure it's what the OP was looking for.
I also have a bunch of jubilee clips I'd love to replace with better looking items. Never have liked them.
The big ones on the coolant hoses, I take those off and put on the good stainless ones that oreilly carries (below). Easier to work with in a pinch like if you don't have a special tool with you. They are kinda pricey but will last forever.
But the special tool is handy when working on one that still has the old spring clamps.
