Hose/line/wire routing for gauges
Hey Guys,
I'll be installing a triple sunpro gauge cluster above the diff lock selector (as seen in some members posts) to monitor oil pressure & coolant temp mainly, the other gauge in the kit does voltage but it's not as important as the first two.
I picked up a oil filter sandwich plate and a 32mm coolant hose tap.
My main question is:
Where/how did you inconspicuously route the lines and wires that feed these gauges?
Some will come from the fuse box area and at least two lines from the engine compartment.
Theoretically "it's the wife's vehicle" which I drive when I can so I need to make it look like a clean install.
Thanks!
Thanks!
