Hose/line/wire routing for gauges
Old Sep 4, 2014 | 05:53 AM
ImQuattro's Avatar
Default Hose/line/wire routing for gauges
Hey Guys,
I'll be installing a triple sunpro gauge cluster above the diff lock selector (as seen in some members posts) to monitor oil pressure & coolant temp mainly, the other gauge in the kit does voltage but it's not as important as the first two.
I picked up a oil filter sandwich plate and a 32mm coolant hose tap.
My main question is:
Where/how did you inconspicuously route the lines and wires that feed these gauges?
Some will come from the fuse box area and at least two lines from the engine compartment.
Theoretically "it's the wife's vehicle" which I drive when I can so I need to make it look like a clean install.
Thanks!
Old Sep 8, 2014 | 05:49 AM
ImQuattro's Avatar
Anyone want to chime in?
Old Sep 8, 2014 | 06:14 PM
redrover75's Avatar
Default search function
A quick search, I think there is even a sticky, will show a couple nice installations.
That is probably why no one replied.
cmb6s
Jul 13, 2014 09:45 PM
wheelgarage
Jun 15, 2012 05:01 PM
JBeezy53
Feb 16, 2011 07:18 PM
Dino76
Aug 19, 2007 10:21 PM
danepeople
Oct 17, 2006 10:10 AM
