Hot Disco (very hot)
Old Sep 29, 2009 | 05:50 PM
twmj1953's Avatar
Still broken. I don't think you can put the heater core hoses on inccorrectly their connected short and long. Got alittle heat out of the vents but only for a moment. Water would pumps out of overflow tank every minute or so. I didn't drive the car so it didn't overheat. The overflow tank bubbles and like I said fluid occationally pumps out. I think there's a crack somewhere, but where?
Old Sep 29, 2009 | 05:58 PM
LRScott's Avatar
I could be completely wrong, but could it possibly just be the resivour cap?
Old Sep 29, 2009 | 06:23 PM
Alex M.'s Avatar
You know I had this same problem no too long ago. I replaced my thermostat and didn't bleed the system.... and oh yeah, I learned that you can put the thermostat in backwards
Old Sep 29, 2009 | 07:14 PM
What else have you done to the truck?
I re-read your post and you may have a blown head gasket.
Old Sep 29, 2009 | 08:05 PM
twmj1953's Avatar
I put new head gasgets on last fall, machined heads, pressure tested, new lifters, rods, wires, water pump, drove for two months, 2,000 miles no problems then overheated. Machanic put on new head gasgets, machined heads pressure tested, started up, overheated, mechanic did again with a different head, same problem. Towed car back home put on thermostat and new cap, here we are.
Old Sep 29, 2009 | 09:49 PM
I would look into the radiator being clogged then.
dgilson4
Oct 22, 2011 07:04 PM
foamwizards
Sep 16, 2011 05:28 AM
MikeThomas
May 10, 2011 10:21 AM
LRScott
13
Apr 7, 2010 02:26 AM
pureanal
Jul 11, 2006 09:29 PM
