Hot start issues
Old Jul 2, 2014 | 04:53 PM
  #21
SuperSport's Avatar
Originally Posted by KernowDiscovery
Well in the typical person's mind, that would be the logical thought SuperSport. Not so when it comes to Offroad
I'm definitely not a "Typical Person", but in this particular case, I took it literal. I must be slipping...
Old Jul 2, 2014 | 06:19 PM
  #22
OffroadFrance's Avatar
.......................................but do I need to learn how to speak French? Thanks for the link.
Nah, don't worry about speaking French they don't or can't understand each other let alone us foreigners. Anyways, seeing some of the Brits here they think speaking French is just SHOUTING louder in English and the French will understand..................hmmm...............I don't think so.
Some days speaking in French all day just gets to you and is hard work and you can't wait to get away from them or just speak in English
Old Jul 2, 2014 | 06:26 PM
  #23
I think we are untypically like minded there. I don't think I can pass for typical either .................. or even normal ..............eeeerrr............what's CPS stand for SS?.......................
That aside, it's Dusty's humour..............it's great.............I love it.............he's a real hoot...................but I sometimes have to ponder awhile on those deep south expressions.............
Old Jul 2, 2014 | 06:58 PM
  #24
SuperSport's Avatar
Deep South??? With all the references to Guns, I thought he was from Chicago!
Old Jul 2, 2014 | 09:03 PM
  #25
dr. mordo's Avatar
I would pull the terminals and clean the battery and terminals. Then check the charging system to make sure the alternator is producing enough volts. If so, drive it for another day or two.
If the problem continues, replace the starter.
Old Jul 2, 2014 | 10:13 PM
  #26
dusty1's Avatar
lol
"that little guy" = I always use in reference to anything around the size of a fist or smaller, that hasn't an everyday common name or even if it has a very descriptive but long name.
it has just become a habitual part of my vocabulary.
and for ss,
Old Jul 3, 2014 | 12:52 AM
  #27
dr. mordo's Avatar
Since I have been watching a multi-day Broken Lizard movie fest, I appreciate your reference.
Old Jul 3, 2014 | 06:22 AM
  #28
Hi there - no, it doesn't turn over and over, it starts turning over and then stops - like it couldn't.....quite................. get there. That's the only way I can describe it. It starts to turn over, decides that it's too pooped and then unwinds or fizzles out. So then I sit there, swear a bit, sigh, try again and it starts up fine.
Does sound like starter circuit electrics KD. Start with cleaning the battery terminals. If that doesn't work it may be something a bit deeper, bad earth strap connections or the 12v exciter connection to the starter motor (common fault where the spade connector is not making a good connection) or even a duff starter motor or at worst the battery is a cell down, even newish batteries fail. Might be worth a ampage load test at a local garage or auto electricians. It could even be the starter motor getting tired (bit like me) or the starter bendix sticking. I hate modern auto electrics - they're far too complicated for what they do.
Remember the old Series LR's, MGB and MGA? even a simpleton like me could figure their way through the electrical systems.
Old Jul 3, 2014 | 06:28 AM
  #29
He may be a reformed Chicago hood, or there again, even a preacherman now
Old Jul 5, 2014 | 11:29 AM
  #30
KernowDiscovery's Avatar
Thanks guys. I've been driving it the past few days with no issues. Checked the battery connections - they look fine. I'm changing the headlight today - probably the filament as you stated - still have to hit it to get it to work. I'll keep an eye on it. Thanks again for all the input
