How to access this bolt
Old Feb 23, 2014 | 12:24 PM
Reza's Avatar
Default How to access this bolt
Can someone tell me how to access this bolt in order to stop a coolant leak. I have the pic of the leak in my earlier post. The bolt tightens the heater inlet pipe. Thanks
Reza
Old Feb 23, 2014 | 12:40 PM
Bryan H's Avatar
Hard to tell in the pic, but if that's the pipe I'm thinking of, there's a o-ring on the neck of the pipe to seal it in the intake. That may need replaced as well.
Old Feb 23, 2014 | 12:42 PM
Reza's Avatar
That is the pipe, but what is the easiest way to access this bolt?
Old Feb 23, 2014 | 01:16 PM
Jared9220's Avatar
Take off the Alternator. If the o-ring needs to be replaced then that is the best way to get to it.
Just disconnect the battery, remove the engine fan, Take off the engine belt, remove the 2 bolts holding the alternator, pry the alternator loose and disconnect the power and ground wire from the back.
Old Feb 23, 2014 | 01:20 PM
TripleThreat's Avatar
If there is a leak coming from there, chances are you will need to replace that O-ring... Tightening that bolt will likely not resolve a leak, it simply holds the tube in the hole under pressure to keep the O-ring far enough in the hole to maintain good contact with the walls of the hole...
Old Feb 23, 2014 | 04:49 PM
Reza's Avatar
Got it. Thanks to all
focusontheworld
Oct 21, 2012 01:00 AM
0304Disco
Oct 15, 2012 05:16 PM
batiscan
Jun 20, 2010 09:06 PM
tallalien
Feb 16, 2009 01:37 PM
GoldDiscoII
Dec 1, 2006 09:51 AM
