How Accurate is the Cylinder ID in a Misfire Code?
Old Sep 1, 2011 | 10:25 AM
Bryan H's Avatar
Default How Accurate is the Cylinder ID in a Misfire Code?
I have a P0304 code that reads as a Cylinder #4 misfire. First of all, how does the computer know which particular cylinder is misfiring? I can understand how it would know a misfire is occuring in a bank (using the O2 sensor), but other than having an injector short, how can a specific cylinder be identified?
For what it worth, Cylinder #4 has good spark, is getting fuel, and has 155 psi compression. I don't have a leak down tester, so I'm not sure about that value.
I'm wondering if the misfire could actually be another cylinder(s).
Thanks for any help.
Old Sep 1, 2011 | 10:43 AM
100%, don't try to second guess it.
Injector issue for number for is a 204.
How do you know you have good spark, who's wires and plugs are you using?
Old Sep 1, 2011 | 11:06 AM
Bryan H's Avatar
Magnecor 8 mm and Bosch +4. I'm basing good spark assumption on seeing the plug spark when I pull it out of the head and run the engine.
Old Sep 1, 2011 | 11:10 AM
Never assume when it comes to a Rover.
You can have a bad coil, carbon knock or a sticky valve causing that code.
Old Sep 1, 2011 | 11:15 AM
Bryan H's Avatar
Mike, any suggested trouble shooting approach based on the above?
Old Sep 1, 2011 | 11:42 AM
And the ECU knows when it just sent a command that should have fired cylinder "X", and the timing involved, etc. It does the math for you. In the old days, some shops had big ignition analyzer scopes, and I could never figure out how to get baseball games on them....
Old Sep 1, 2011 | 12:48 PM
Bryan H's Avatar
If I crossed up two of the wires on the coil packs, would I get a second cylinder misfire code? Or is it possible that I could just get a single code for #4?
slabrat
Apr 5, 2013 12:18 PM
scarrell
Nov 16, 2012 06:04 PM
FLDISCO
Nov 18, 2011 07:53 AM
rover
Freelander
Apr 28, 2008 08:42 PM
lajilana
Sep 2, 2006 10:47 AM
