How to attach a D1 brush guard to a D2?
that is pretty much the same as the OEM D2 guards except that little nudge bar below the lights. same removable light guards and everything. do you have a brush guard on your truck now? there are cutouts on the plastic bumper that need to be cut out that will give you access to the mounting points on the frame.
You'll need these, I had them on my DII when I pulled the factory guard off. Other than that, it should bolt up fine. The frame widths are the same from the DI-->DII as I put a DI winch tray on my truck.
Brush Bar Mounting Bracket Kit - Exterior Accessories for Land Rovers & Range Rovers
Not the best picture, but it's all I got.
This is my truck with the factory brush bar removed. Not sure which bumper you have, but regardless, you'll most likely have to make some cuts in it for the brush bar to slip through and bolt to the mounting brackets (sold separately, see response above).
The (crooked) yellow arrows point to the slots that were cut in my bumper from the factory. As you can see they are very small.
DSC_0195-2.jpg?t=1324318331
Step One : Bolt Brush Bar Mounting Bracket Kit - Exterior Accessories for Land Rovers & Range Rovers to Frame
Step Two : Bolt Brush Bar to Brush Bar Mounting Bracket Kit - Exterior Accessories for Land Rovers & Range Rovers
Hope this helps!
Hope this helps!
I gave you a link for the mounting adapters
I showed you approximately where you'd need to make cuts in your bumper.
Did I miss something?
Brush Bar Stabilizer Bracket Kit
Hi Rob,
I have factory brush bar without mounting brackets and thanks a lot for the instruction I'm going to order a pair of Brush Bar Mounting Bracket Kit (Item: STC50192G) from Atlantic British Ltd.
Do I also need Brush Bar Stabilizer Bracket Kit (Item: STC50320G)? Brush Bar Stabilizer Bracket Kit (Genuine Part # STC50320) - Land Rover bolts\clamps\brackets\washers from Atlantic British
Where can I find photos or installation instructions?
Many thanks!!
Paul
2000 Disco 2 SD
Many thanks!!
Paul
2000 Disco 2 SD
Whats up with you..
Hope this helps!
Hope this helps!
LOL.... C.
