How bad is this T-case leak?
Old Aug 10, 2011 | 08:15 PM
brigadier_dj's Avatar
DiscoRover007 I have almost the exact same scenario going on with mine. I swapped my driveshaft about 4 months ago and I developed an ominous vibration from 70-75. I thought it was the shaft but I have a VERY wet t-case that's definitely gear oil.
I am very nervous about all this. haha
Old Aug 10, 2011 | 10:53 PM
KenR's Avatar
I've got that vibration too. The oil is definitely from the transfer case but I'll have to look closer to see if it's coming from either output shaft. If anything, it'd be the front in order to get the oil to where it's at.
Strange thing about the vibration - while trying to diagnose it I pulled the front driveshaft, locked the CDL, went for a drive and still had the vibe. I'd think if the front output shaft seal and bearing were bad I wouldn't feel the vibe, no?
Old Aug 11, 2011 | 08:32 AM
jeffh's Avatar
so to be clear... I was referring to the output shaft seal from the transmission not the T/c. And if it leaks it will cover your T/c in all the ways that are shown in the pictures. I had this problem... I know. While I certainly hope that all of your leaks are the T/c I am just saying that you might want to consider this as a reality as well.
Old Aug 14, 2011 | 05:55 PM
i hate to say this, but i took the shaft out,
no vibration.
Old Aug 16, 2011 | 11:46 AM
sloan74's Avatar
I thought all D2s looked like those pics underneith?
That definitely looks like fresh gear oil though. Your crossbar looks very wet. So I would definitely try to pin point and get it fixed.
dparham
Apr 22, 2013 04:03 PM
starcraft1
Nov 13, 2011 08:14 PM
oljohnboy
Sep 14, 2009 03:01 PM
rgrizzard
Mar 6, 2008 10:16 AM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
