How to bleed coolant without bleeder screw?
Old Jun 24, 2021 | 06:24 AM
mln01's Avatar
Originally Posted by Oshawa_D2
here you go
unless the first photo is the bleeder screw? It thought it would be on the at connector?
Uh, wow. Yes, that's the bleeder screw. It's not a "non-standard" part; it's the original design for the upper radiator hose.
That design was replaced part way through the DII production run. It had by then become known as a failure point, where the screw and its mount would "blow out," causing a catastrophic failure of the cooling system. In the updated design, the bleed screw was moved to the T fitting. I recommend you spend the few bucks to update the upper radiator hose in your truck to the "new" design version.
I know this in part because it happened with my truck. After I replaced the headgaskets 11 years ago this month, the cooling system was again pressurized and two weak points were soon "revealed."
First was the bleed screw. It blew out mid-way through my 15-mile drive home after work. Thankfully I was at a stoplight next to a gas station. I pulled into the gas station lot and used a golf tee held in place with some duct tape to plug the hole well enough to limp the rest of the way home after topping up the system with water. Fun times!!! The second weak spot revealed was the throttle body heater gasket; a well-known problem.
Old Jun 24, 2021 | 10:50 AM
nashvegas's Avatar
Yes, that's funny, you still have the factory bleed screw which was in the upper radiator hose. Never see those any more!
They then replaced it with one in the T that we're all familiar with.
Old Jun 25, 2021 | 06:28 AM
Extinct's Avatar
Just convert to the inline thermostat mod and you can forget about bleeding, bleed screws, plastic tees and plastic thermostats. In your case you probably should change that top radiator hose as it is at least 17 years old
Old Jun 29, 2021 | 03:48 PM
Oshawa_D2's Avatar
Originally Posted by Jason_B
The coolant res unclips from the rear side, you just need to force it up and it will come up with the hoses and lines attached.
rear side you mean the side facing to the passenger compartment?
Old Jun 29, 2021 | 04:02 PM
Oshawa_D2's Avatar
Originally Posted by acg
With the 180 thermostat... running temp is typically around 186F to 194F for me, with up to 201F when idling. Sudden spikes in the temps could point to air in the system. Or the waterfall sound usually coming from the glovebox area.
same with mine
discorey
Jul 15, 2016 04:06 PM
DiscoCam
Oct 18, 2015 05:43 PM
jamestfl
Feb 1, 2014 10:05 AM
DiscoBenjamin
Feb 24, 2011 10:37 AM
03discoman
May 9, 2010 09:46 PM
