Cracked Bleed Screw
Old Feb 24, 2011 | 06:47 AM
DiscoBenjamin's Avatar
Default Cracked Bleed Screw
I cracked my bleed screw and replaced it with a metric screw. FYI, a fine threaded 10 MM screw works perfectly, but is there a reason the bleed screw is plastic and will this cause problems?
Old Feb 24, 2011 | 07:08 AM
dcarr1971's Avatar
It shouldn't...others have found a brass replacement and are apparently happy with them. (I have two in my kit even as we speak, just haven't got around to installing them.)
Old Feb 24, 2011 | 07:24 AM
jeffh's Avatar
I have had the same thing happen. I replaced the screw with a nice brass one. fits perfect and will only be overkill...
Old Feb 24, 2011 | 08:29 AM
Bundu's Avatar
Banned
The key is to finger tighten the screw so that you do not blow the threads in the T piece, otherwise you will be shopping for a T piece as well. The bleed screw has a channel in the thread to allow air to escape when you bleed the system a regular screw does not - that's the only down side I can think of. The bleed screw also has an o ring, but you can slap the old o ring on your new screw.
Old Feb 24, 2011 | 08:47 AM
Any reason for using Brass instead of regular metal?
Old Feb 24, 2011 | 10:00 AM
bosshogt's Avatar
Anti corrosion since it's around corrosive Dex-cool. And it's cool engine bling like the brass fill diff plugs.
Old Feb 24, 2011 | 10:37 AM
Bundu's Avatar
Banned
Stainless steel will also work.
akbarkhan
Aug 18, 2013 01:29 PM
MARGE
Feb 29, 2012 05:24 PM
99discoverysc
Jan 14, 2010 04:37 PM
JAC
Oct 1, 2009 04:02 PM
flyingasics
May 24, 2007 07:42 AM
