how to center steering box
Old Feb 23, 2022 | 08:16 AM
me 2's Avatar
Default how to center steering box
Replaced steering box and shaft and found that the box is off center. Is there a way to line it up center? Thanks again for any help!
Old Feb 23, 2022 | 06:20 PM
ahab's Avatar
There's a process in the RAVE. If it's off more that 10° or something you need to disconnect the steering shaft from the splined shaft sticking out of the box and realign the splines. There's a "home" in the bottom of the box and you thread an M8X100mm or something into the locating position, then center the wheel and slide the splines back together. You're actually supposed to do that before installing the box. Minor adjustments are done at the track rod by loosening the two clamps and rotating the coupling near the passenger side wheel, front side of the axle.
Old Feb 23, 2022 | 08:09 PM
JohnZo's Avatar
Track rod and drag link are easy to adjust, so long as the threads aren't all rusted up. Apply lots of penetrating oil. I had to cut slots in mine to get them free.
Ben Matheson
Nov 3, 2018 09:37 AM
Club Cheetah
Aug 21, 2016 04:58 PM
coors
Jan 31, 2016 03:36 PM
evansjoem
May 12, 2014 07:09 PM
texci77
Jun 6, 2012 01:24 PM
