How to change the heat readout from C to F
Old Dec 19, 2007 | 07:27 PM
seaosrover's Avatar
Default How to change the heat readout from C to F
How do I change the display on my heater to read F instead of C. I noticed in the book it is in F and on my 03 disco it is in C.
Old Dec 19, 2007 | 07:29 PM
jmt's Avatar
jmt
Default RE: How to change the heat readout from C to F
I had the same issue in mine. It says in the manual how to do it, but off the top of my head, I believe you hould down the "Econ" button and then push the power button.
HTH
Old Dec 19, 2007 | 07:33 PM
seaosrover's Avatar
Tried that just now did not work.
Old Dec 19, 2007 | 08:15 PM
Read your owners manual.
Old Dec 19, 2007 | 08:28 PM
okdiscoguy's Avatar
Ok, I'll give you a hint.....
The AC system must be on- press and hold the recirculate button and then press and hold the power button at the same time, both F and C come up and within three seconds it switches to the opposite of what is already set.
Old Dec 19, 2007 | 09:05 PM
Probally already got it, but...http://www.roverparts.com/TechTips/T..._C_to_F_D2.cfm
Old Dec 20, 2007 | 08:04 AM
jmt's Avatar
jmt
Ahhh.. Recirc. I knew it was one of those.
Old Dec 20, 2007 | 06:46 PM
seaosrover's Avatar
Thanks discoguy
Old Dec 21, 2007 | 10:44 PM
okdiscoguy's Avatar
no problem....
jmason
Nov 17, 2013 06:39 AM
AZRover
Aug 19, 2013 10:56 PM
collin Barrows
Aug 28, 2011 07:13 AM
booman
Nov 30, 2009 09:54 AM
rlsmoyermd
Jan 27, 2008 09:35 AM
