How to check an engine mount
Old Nov 23, 2009 | 07:30 PM
lipadj46's Avatar
Default How to check an engine mount
How can you tell an engine mount is bad? Can it cause a slight rough idle or rough running from being loose? I know it can cause a clunk.
Old Nov 23, 2009 | 09:40 PM
Willie00d2's Avatar
Try to pry the engine up with a pry bar and see if the rubber is cracked.
Willie
Old Nov 24, 2009 | 08:29 AM
XCELLER8's Avatar
Cool
can't speak from rover experience but I had an engine mount go on a 99 chevy blazer and the engine would shake around @ idle but smooth out as you hit the gas. I think I've read here about transmission mounts getting "soft" , since they are all connected that may be worth looking at ?
Old Nov 24, 2009 | 09:26 AM
At your mileages, yours should be shot. If they are failing they will have a crack across the rubber area, even if not cracked, they do get soft and warn and will allow the engine vibration to transfer to the frame.
Old Nov 24, 2009 | 11:21 AM
lipadj46's Avatar
That's what I figured. Is changing them as simple as loosening the mounts, jacking up the engine and then replacing the mounts and then lowering it back down?
Old Nov 24, 2009 | 04:57 PM
StevenDiscoII's Avatar
From looking at them culprits, I may be next in line to replace them.
Old Nov 24, 2009 | 05:06 PM
that's what i figured. Is changing them as simple as loosening the mounts, jacking up the engine and then replacing the mounts and then lowering it back down?
"yup"!!
Old Nov 24, 2009 | 05:50 PM
lipadj46's Avatar
One of mine looks really rough. I can get both mounts for $80 so I am going to do that next.
FlyingZebra34
Feb 22, 2014 05:39 PM
khuds308
May 13, 2013 09:48 PM
slave600
Sep 8, 2008 08:00 PM
tads
Aug 2, 2007 12:09 PM
miishmiish
Mar 8, 2006 12:31 AM
