How do front cover relief valves work?
Old Mar 22, 2016 | 05:47 PM
LandRoveris's Avatar
Default How do front cover relief valves work?
Hello,
Land Rover and Range Rover Picture by LandRoveris | 5221387 | LandRoverForums
I am in the middle of an engine overhaul on my 1999 D2. I have the front cover taken apart. I have removed the oil pump gears and the pressure valve (marked #1 in image link) which is visible under the gears.
Unfortunately I hear something still moving around in the cover like a ball bearing or a very freely moving piston. I can shake the cover and it would make a spray paint can type rattle. Is there another piston in area marked #2? If so, should it be sliding loosely? Should I inspect it for free movement?
I had a hell of a time getting the spring plug out from #1 so I don't want to remove this without reason.
Thanks!
Old Mar 24, 2016 | 02:24 PM
Bump
anyone?
Old Mar 25, 2016 | 06:21 AM
coors's Avatar
Exclamation
Other than swapping out the pump gears I have not cross someone that has attempted to rebuild the oil pump relief system. I wasn't aware it was serviceable.
Hang tight. I'm sure few members will chime in with advice.
Old Mar 26, 2016 | 12:26 AM
number9's Avatar
Saw this recently.
Land Rover Workshop Manuals > Engine Overhaul Manual v8 4.0 4.6 > OVERHAUL > Oil pressure relief valve - remove
Old Mar 26, 2016 | 10:09 AM
Charlie_V's Avatar
There are two valves, one on either side of the oil pump. If something is rattling it has to be on of the pistons, which would mean a broken spring. Both of the valve setups look identical when you have them out, and neither should be moving around.
I took mine apart last week. It is a not a pleasant task.
My front cover was scored and is now junk so if you need some pictures let me know.
RicketyTick
Apr 25, 2014 08:11 PM
RicketyTick
Apr 25, 2014 08:03 PM
ruffram
Sep 1, 2011 08:15 PM
aerokurt
Dec 5, 2006 06:34 PM
Bait
ROAMING WITH FRIENDS
Sep 21, 2005 11:44 PM
