Sponsored by: CARiD
Oil pressure relief valve in BACKWARDS
Old Dec 5, 2006 | 02:24 AM
aerokurt's Avatar
Default Oil pressure relief valve in BACKWARDS
Hi all,
Well, after removing the timing cover and finding the oil pump o.k., looked around for the relief valve behind the cover, not there, in fact it was accessable from outside the engine, if you knew where to look.
All covered in grime, so invisible to the untrained eye, was a circlip at the end of an oil gallery on the passenger side of the timing cover.
This removed, revealed a curious arrangement of spring and valve. The piston and spring did not mate well when the piston is in backwards!!! It took a few moments to analyse the gallery arrangements and flow patterns, and to realize the piston was made to recieve the spring from one direction only, not the one we found.
Also found a loose timing chain without any tensioner system.
Anyone know if this is normal ?
Cheers.
Old Dec 5, 2006 | 06:34 PM
Default RE: Oil pressure relief valve in BACKWARDS
I believe the timing chain tensioner is operated by oil pressure thru a hydralic tensioner.
Mike
Fast951
Sep 26, 2019 09:15 PM
Petrou11
Apr 2, 2015 02:28 PM
JimmyTomahawk
Jan 28, 2014 12:23 PM
4x4trouble
Feb 2, 2012 07:27 PM
vishrb
May 24, 2011 03:54 PM
