How do I drain fuel tank?
Old Jun 19, 2024 | 07:10 AM
Extinct's Avatar
Modern fuels are risky at that age and with that quantity. The alcohol tends to separate unless it has had Sta-Bil added to it and the alcohol absorbs water from the atmosphere and they also gum up really badly in small orifices. I had a boat I had to pull the tank and drain a few years ago, about 1/8 water it seemed (you could see it because the tank was translucent). Small engine carburetors are notorious for gummoing up the idle jets and floats sticking due to old fuel. Not saying it wouldn't work but you might want to consider the drain path and then slowly use the fuel over time blended in with larger quantities of fresh fuel.
Old Jun 19, 2024 | 08:15 AM
PickleRick's Avatar
Today's gasoline, even the expensive non ethanol that will likely test positive for ethanol, has a shelf life of about ,2 weeks to 30 days without a stabilizer being added while it was still fresh.
I love today's gasoline, keeps my shop busy. Doesn't matter if it's a plastic or metal container. Aluminum, stainless, galvanized...fuel goes bad just the same. Plastics just won't corroded or rust.
Old Jun 19, 2024 | 02:52 PM
Harvlr's Avatar
I would not use 5 year old fuel in any engine that I liked.
Old Jun 20, 2024 | 08:32 AM
Externet's Avatar
I see the fuel pump as a good way to drain it. There is no rust settled in a plastic tank to clog a filter. And if there was any and the tank is not cleaned when purging the fuel; it will go into the filter later when new fuel is loaded.
I believe a hose is obstructed to insert trough the fill neck as in siphoning from outside ? And I would add in small amounts to the new fuel or use in a mower...
Old Jun 20, 2024 | 12:48 PM
evil_goat's Avatar
Would storing gasoline in 5 gallon buckets with lids be safe? Some places online say it will cause an explosion, others say it is fine. It does get pretty hot here, but it would be stored in a large barn/shop.
Old Jun 20, 2024 | 12:57 PM
H20nSnow's Avatar
And by "in a large barn/shop", you mean "OUTSIDE a large barn/shop"!?
Old Jun 21, 2024 | 05:17 AM
Extinct's Avatar
When I drained the fuel out of my boat I scored a free 55 gallon steel barrel off the local craigslist, kept the fuel in there and dipped it out by hand a gallon at a time and used it in my D2's. 1 gallon in a 20 gallon tank is a lot of dilution and it worked fine. There was about 5 gallons of water at the bottom so when I got down to that level I stopped. Kept in outside in a paved area on the driveway away from everything else of value. Kept a lid on it but not tight so as to create a pressure vessel - normal temperature changes will cause significant pressure changes in a container of gasoline. Never had a problem but always respected the potential fire danger from spark and temperature.
Frani
LR2
Nov 14, 2022 08:49 AM
slickooz
Mar 24, 2014 02:40 PM
mrossipir
May 15, 2013 09:53 PM
sdyver
Jan 5, 2013 02:01 PM
Snafu / Disco Fries
Jun 20, 2011 08:26 AM
