How to drain fuel tank
Old Nov 10, 2022 | 01:17 PM
Frani's Avatar
4th Gear
Default How to drain fuel tank
Husband accidentally filled my 2010 LR2 with diesel, how can we drain the tank
Old Nov 10, 2022 | 05:40 PM
flybd5's Avatar
There is no drain for it. You will have to drop the tank, remove the fuel pump and empty it through there. You can't siphon it through the fill cap either, there is a device inside the tank filling opening that prevents you from doing that so someone cannot steal your fuel.
Old Nov 10, 2022 | 10:04 PM
merlinj79's Avatar
Yeah, have to drop it to drain.
Although if you're creative enough you could probably hook up a hose to some point in the fuel system and power up the pump to empty it out. That's probably what I would do, but would need to divert a fuel line somewhere and possibly tap into the wires to the pump to power it... not sure how long the pump will run without the engine on, and you *really* don't want to run the engine.
Old Nov 11, 2022 | 06:51 AM
flybd5's Avatar
And when you drop it have someone install a drain plug at the lowest point in the tank to husband-proof your car.
Old Nov 14, 2022 | 08:49 AM
guy's Avatar
guy
I’d siphon it out as best I could, first. Probably not with a cigar in mouth ;-)
Guidumar
Jun 9, 2025 10:22 PM
vanbadri
Nov 13, 2022 10:29 AM
_Allegedly
Jun 22, 2022 12:46 AM
MTboggs
Apr 16, 2017 07:41 PM
DavC
Jan 16, 2015 02:30 PM
