how do i get these darn lug nuts off!?
Old May 28, 2011 | 12:42 PM
sorusty's Avatar
Default how do i get these darn lug nuts off!?
I am trying to change my front brake pads on my 2001 Disco II, but i cant even get the lugs off. Is there a cover over the lugs i need to pop off first. They wiggle back and forth so i know they are not the lugs. I cant get them off though. anyone have any suggestions? i tried using a screw driver to pop them off. no luck.
Old May 28, 2011 | 12:58 PM
jafir's Avatar
The covers don't come off (except as a last resort). They are an assembly and come off together.
Old May 28, 2011 | 05:21 PM
MattyMatters's Avatar
If your not able to budge the Lugs in order to remove them.... at least that's what I'm getting from your post... Then you need to grab a pipe that fits over your Lug nut wrench handle - making the wrench handle longer and easier to loosen those rusted-on lugs - and then try to loosen them. The longer the handle is, the less effort needed to loosen them. Once you have them off, use a wire brush to clean up the Hub Assembley and apply a small amount of grease to each screw making them easier to get on and off in the future.
Hope this helps
MattyMatters
02 Disco 'Black Betty'
Old May 29, 2011 | 12:57 PM
tshah209's Avatar
I use my breaker bar with a 22 mm 1/2 drive socket. After I loosen, I then use my drill with a socket bit to do the rest.
Old May 29, 2011 | 01:36 PM
antichrist's Avatar
Also, righty-tighty lefty-loosey.
Old May 29, 2011 | 09:27 PM
jafir's Avatar
By lefty-loosey, I think you mean "anticlockwise"
Old May 30, 2011 | 01:52 PM
sorusty's Avatar
thanks to all that responded. i ended up bending my lug nut wrench and went to Autozone and purchased a socket to use. I already had a breaker bar, i also had to use the jack bar as an extension to break the lugs free. The brake pad were really easy to change out. Took me about 20 minutes once i had the tire off. thanks again.
Old May 30, 2011 | 01:58 PM
agthird's Avatar
I use a three foot cheater bar taking them off don't over torque them going back on...
Old May 30, 2011 | 03:03 PM
DarylJ's Avatar
OK, well, that was the problem to begin with. The lug wrench that comes with the truck is basically a one time use emergency tool, not something you use for service work.
Old May 30, 2011 | 04:09 PM
jafir's Avatar
I think land rover put it in there as a joke. You know, English humor like Monty Python.
Alex_M
Apr 5, 2015 01:14 PM
dcarr1971
Feb 8, 2013 08:16 AM
rsomp
Jun 14, 2012 12:45 PM
bcolins
May 13, 2011 01:31 AM
Torancis_LR
Apr 29, 2010 03:25 PM
