How do I get these sunroof drain tubes back down into the a pillar?
Old Oct 16, 2019 | 08:00 PM
Brandon318's Avatar
Default How do I get these sunroof drain tubes back down into the a pillar?
I took the sunroofs out to clean and reseal. The plastic drain connectors were still connected so rather than risk breaking them, I made the stupid mistake of leaving them connected and removing the tubes. The rear tubes routed back through just fine, but these a pillar tubes for the front are getting jammed where the a pillar bends down into the door jamb. Feels like they aren’t making the turn. Help?
Old Sep 16, 2020 | 12:39 PM
nashvegas's Avatar
In the middle of this EXACT issue. Anyone run into this / have ideas?
Old Sep 16, 2020 | 01:11 PM
Brandon318's Avatar
Yep! I ended up buying this Klein fiberglass fish tape. https://www.homedepot.com/p/Klein-To...6371/311464756
The fiberglass won’t scratch the inside of the a-pillar and the bullet-shaped end of the fish tape will mate nicely with the end of the drain tube. Run the fish tape up from the bottom of the car where the drains drain, thread it into the passenger compartment, secure the end of the fish tape into the end of the tube and wrap with electrical tape, and then pull it down through the a-pillar.
Old Sep 16, 2020 | 02:15 PM
nashvegas's Avatar
Just what I needed, I thought doing it from the bottom might be the trick. Thanks.
Old Sep 16, 2020 | 02:50 PM
greisinb's Avatar
Once you have fish tape you'll wonder how you ever survived without it.
DiscoNoisebox
Jul 15, 2022 10:15 PM
sputnik62
May 28, 2018 10:50 AM
Frank4
Jul 31, 2016 09:05 AM
Gerard
Feb 20, 2011 06:54 PM
mburnett
Jun 5, 2008 09:18 PM
