How do you clear SLS warning light???
Old Dec 27, 2009 | 04:38 PM
rankar's Avatar
Default How do you clear SLS warning light???
Guys, I did a search but couldn't find a related topic on this.
Do you know how to clear an SLS warning light? I've installed springs and removed the ol' air bags and now want to clear the warning light.
Can this be done via ODB? Or is this a dealer job?
Thanks all
Old Dec 28, 2009 | 09:01 AM
jeffo's Avatar
I have recently replaced my bags with springs. You need to find someone with the correct scanner to have the slab unit reprogrammed from bags to coils. If you dont do this the ride height sensors will tell the compressor to come on all the time. You should pull the SLS relay in the engine compartment fuse box to avoid battery drain. To avoid the over 20 mph chime that the additional 2 inches of lift will cause, disconnect the ride height sensors. This will allow you to operate normally until you can have the reprogramming done.
Old Dec 28, 2009 | 09:02 PM
rankar's Avatar
Thanks for the reply. Definitely did yank the relay, so I don't hear the whirring of the compressor (I do miss that sound btw). It sounds like a dealer job then. I wonder how much they'll charge for that gem of a job...
Old Dec 28, 2009 | 09:05 PM
Yes you need the stealer to do this for you, should take about 10 min and they will prob charge you for 1 hour labor.
Old Dec 28, 2009 | 09:15 PM
rankar's Avatar
I guess I can do what I saw this cabbie do recently, put a black piece of tape over the warning light... thanks guys for your help.
Old Aug 21, 2010 | 06:53 PM
caiogaucho's Avatar
It was exactly what I did! At least the battery is not discharged more!
[]'s
Caio
Old Oct 22, 2010 | 10:55 AM
timmay7t's Avatar
i pulled the fuses today. hopefully my battery will stay charged, i'll update in a day or two to see if it worked
Old Nov 1, 2010 | 08:13 AM
timmay7t's Avatar
it worked, now i don't have to keep the jumper cables on the front set anymore......
Old Nov 1, 2010 | 09:09 AM
hilltoppersx's Avatar
some indie LR shops may have an SLS reader as well. my local guy does and he didnt charge me a dime. (thats cuz i throw him business though)
Old Nov 2, 2010 | 10:18 AM
rankar's Avatar
I called Atlantic British and they've got a list of indie folks with the right stuff. They connected me with a shop about 12 miles or so from my house. Went to see them, 10 minutes or less of programming and $20 got everything squared away.
cipher982
Nov 9, 2019 11:22 AM
calebbo
Oct 12, 2011 09:54 PM
maxferran
May 13, 2007 08:30 PM
kkrover
Jun 19, 2006 12:13 PM
