How do you get 1/2" square fill plug out of the
Old Aug 22, 2009 | 11:48 AM
grussell's Avatar
Default How do you get 1/2" square fill plug out of the
swivel ball housing? I have used PB Blaster and a 1/2" wrench won't break it lose. I have checked a few auto parts stores for a 1/2" square socket and found none.
Old Aug 22, 2009 | 11:53 AM
You will probably need a 1/2" breaker bar, at least 2 feet long.
I take mine of with my 1/2" socket wrench and a 2 or 3" extension and a lot of grunting.
Make sure to check the magnetic drain plugs for things other then the usual magnetic mud, like little chunks.
Old Aug 22, 2009 | 11:56 AM
antichrist's Avatar
Get an 1/2" drive 8pt socket at Sears.
An 18" breaker bar should be more than enough unless it was installed by an idiot.
When you put it back in, use a drive handle no more than 8" long, or hold your breaker bar 8" from the socket so you don't over tighten it.
Old Aug 22, 2009 | 12:08 PM
llesra's Avatar
i just used an adjustable wrench to take out the swivel ball fill plug. mine didnt put up too much of a fight though.
Old Aug 22, 2009 | 05:28 PM
I just use a standard open end wrench, 1/2".
You can tap the wrench with a hammer to loosen it.
Make sure the threads are clean before you put the plug back in.
Old Aug 22, 2009 | 06:59 PM
AK Rover's Avatar
Brute force and ignorance will remove any bolt.
Old Aug 22, 2009 | 07:31 PM
antichrist's Avatar
http://www.sears.com/shc/s/p_10153_1...=1/2%22+socket
Old Aug 22, 2009 | 07:36 PM
LANDZUII's Avatar
I also used a large adjustable wrench to brake it loose.
Old Aug 23, 2009 | 09:33 PM
grussell's Avatar
Thanks, the 1/2" wrench wants to round the corners, so it's off to sears for the 8 pt socket.
jycsalas
May 23, 2019 03:02 PM
Rover_Hokie
Oct 1, 2009 11:33 PM
josemex
Jul 31, 2009 09:58 AM
Disco Alan
Apr 21, 2009 06:22 PM
jrkstore43
Mar 2, 2009 08:27 AM
