How do you raise and lower a power window in a junk yard?
Old Jul 25, 2014 | 04:42 PM
  #21
RicketyTick's Avatar
Originally Posted by dr. mordo
Ok, I'm back.
I pulled the window frames using Paul's instructions. I had them both out in 20 minutes.
Then I pulled the driver's side A frame cover for practice. It pretty much came right off. So I pulled the passenger side, and it was easily twice as hard to get out. I ended breaking the top clip, but otherwise it's good. RicketyTick, I'll pm you the total when I have it packed to ship.
Then I started looking for stuff to grab. I pulled the drivers side rear lock because mine's dragging. I pulled the ABS modulator switch, because I suspect mine has failed. I pulled the rear wiper arm because I'm gonna try to mod it so I can replace the blade. I got the rear cup holder. Tip: straighten a couple of hose clamps and slide them in the ends of the cup holder and it slides right out.
I just realized I forgot to grab the front cup holder, which I planned to get as a spare. I wanted the rear door handle cover (back of the truck, next to spare), but the rear door was stuck closed. I thought about grabbing the ABS modulator itself, but it was $50 and the hose nuts were really stuck. I'm trying to think if there's anything else I should grab. The alternator's gone. I didn't check to see if the starter is still there, but I probly should have grabbed it.
It ended up being $83 total.
Thanks for all the help, fellas!
PM sent. if you made it home with the drivers side I'll take it too, if you got it and want to let it go. I looked at my drivers side just now and it is cracked up where the rivets go.
Walko327
Mar 8, 2013 10:23 AM
jrm123180
Aug 29, 2011 09:12 PM
GARovee
Nov 29, 2010 11:13 AM
Aj6543
Oct 5, 2008 05:48 PM
Aj6543
Off Topic
Oct 4, 2008 09:53 AM
