a junk yard steering box?
Old Aug 29, 2011 | 08:33 PM
jrm123180's Avatar
Default a junk yard steering box?
I have a pile of play in the steering on my 2003 Disco, as well as a leak somewhere. I have been thinkinking about getting one from a junk yard...they warranty it for 1 year. Sound like a good idea? Do they usually go bad?
The previous owner had the PS go so he drove it around with no PS...i'm sure turning that wheel with the car not moving caused a lot of strain on the steering box.
Thanks!
Old Aug 29, 2011 | 08:37 PM
disc oh no's Avatar
I believe there is an adjuster on the box, take a look at the RAVE manual or maybe someone who has adjusted theirs could advise you better than I could. As far as driving without the PAS pump working??? I don't know what kind of damage if any that could do... hopefully none but, I really don't know. I'm sure someone with more experience with this particular problem will chime in at some point and send you in the right direction.
Old Aug 29, 2011 | 09:07 PM
jrm123180's Avatar
I did try and adjust it...didn't help much.
Old Aug 29, 2011 | 09:12 PM
disc oh no's Avatar
Hmmmmmm... Maybe a junk yard box would be the way to go then, possibly the gears are just too worn out and slop can't be adjusted out???
http://roverlandparts.com has them for $275 but, if you've got a local junk yard that has some Disco's that may be a lot cheaper.
Walko327
Mar 8, 2013 10:23 AM
Dodger
Sep 1, 2011 01:01 AM
GARovee
Nov 29, 2010 11:13 AM
Aj6543
Oct 5, 2008 05:48 PM
Aj6543
Off Topic
Oct 4, 2008 09:53 AM
