How do you remove SAI tube from block?
Old Jul 23, 2010 | 11:12 AM
Bryan H's Avatar
Default How do you remove SAI tube from block?
I'm pulling the motor out of my '03. It will be replaced with an '04.
As I tried to unbolt the driver's side air tube from the block, the tube turned with the nut (instead of the nut spinning on its own) and kinked the air tube at the flex joint. Before I prepare the '04 motor for installation, I need to remove the sai valves....but I don't want to damage the tubes like I did on the other motor. Anyone have experience with this? I assume these get removed during HG replacement, so I know a LOT of you guys have done it.
Thanks,
Bryan
Old Jul 23, 2010 | 11:43 AM
'BamaBoy's Avatar
Thanks,
Bryan
I just took mine off last week when I replaced my valve cover gaskets. Did you loosen both nuts and then take it off, or did you take one nut completely off at a time?
When I tried taking one completely off at a time and I had the same problem, so i had to screw the unbolted one back in a little bit to loosen the other one up.
Putting them back on is more fun yet....
Old Jul 23, 2010 | 11:56 AM
Bryan H's Avatar
Well, I only tried one. As soon as I started turning the driver's side, front tube nut, the tube was turning with it.
Old Jul 23, 2010 | 12:03 PM
'BamaBoy's Avatar
Humm....I didn't have that problem. I'm curious to know if anyone else on here has had that problem with their SAI.
Sorry I couldn't be of more help.
Old Jul 23, 2010 | 12:21 PM
Bryan H's Avatar
np. I appreciate the input. Who knows, maybe the '04 motor won't do it.
bosshogt's Avatar
Yes, I removed both on the Pass and drivers side to inspect how carboned up the ports were when tring to solve a bad idle about 1 year ago. I would use WD-40 or Deep Creep the night before and spray it 5 times. Mine still twisted a little, but let up as the large brass nut turned. The SAI pipe on the driver's side did not fair so well and I crinkled it. I don't know of any good way to do it other than penetrating oil. Maybe hold the pipe with a cresent wrench and a towel.
I have some spares for sale from an 04 engine with only 37k if it goes bad for you.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
http://stores.ebay.com/Mountain-Bike...r-Parts?_rdc=1
Old Jul 23, 2010 | 02:39 PM
vandev's Avatar
Default yes..
yes, take the heads off with the adapters or you will be buying new ones and they are not cheap. I just tore my motor down this week and got the heads off with the pipes attached. when there off you can get 2 wrenches in there so you dont screw them up. The problem lies with the adapter in the head. Mine where loose as some Fu$ck wad did not retap and get "New" adapters and seal them in correctly..i had no problem getting the heads off with them attached. heck my fan is still atached...yea...lazy... mine is a 04 DII
AK_Rover
Nov 16, 2012 04:27 PM
Thekid
Sep 20, 2012 07:53 AM
DooDer
May 12, 2012 02:40 PM
sbaldwin243
Mar 25, 2011 10:04 AM
Antmen
May 22, 2010 05:19 PM
