SAI tube is almost impossible to get out
Old May 22, 2010 | 10:30 AM
Antmen's Avatar
Default SAI tube is almost impossible to get out
In the middle (or should I say the "beginning") of replacing my wires and plugs (Magnecor 8MM and Bosch +4s) and I gotta tell you...
rebuilding the driveshaft was easier than trying to take out this SAI tube.
I slide it toward the driver/bank 1 side and move the cooling hoses and throttle cable over it... then move back toward passenger/bank 2 side, but there's not enough room to twist it so that the bent single-end side comes out.
Any tricks? In the meantime, about to pour some Scotch. Seriously.
-Anthony
Old May 22, 2010 | 12:19 PM
Antmen's Avatar
Well, I got it out. 'Not looking forward to putting it back in though... that's for sure.
The "trick" was to slide it to driver side/bank 1, move the cooling hoses and throttle cable over the opposite end (just as the directions in the write up) then as you pull it back to passenger side/bank 2, somehow twist it up and over (toward your body) and slowly pull it out.
2 hours on this. I was so tempted to pull the IM by then.
The rest should be cake. (Famous last words.)
-Anthony
Old May 22, 2010 | 12:35 PM
DiscoWest's Avatar
-Anthony
I think you'd be better off pulling the intake manifold with the sai system to deal with, it's a tight fit without sai, with it it's very cluttered.
Old May 22, 2010 | 01:46 PM
Antmen's Avatar
yeah - i know it can be done without having to remove it, but I'm leaning toward ordering an IM gasket and doing that as well.
Now, I just broke a spark plug and it's stuck in my socket. I should've used a bar or extension instead of just the spark plug socket with universal joint.
Fun.
Old May 22, 2010 | 01:56 PM
DiscoWest's Avatar
Fun.
Unless your intake manifold gasket is cracked or otherwise damaged you may be able to use it again. That's what I did and it has worked fine, although I did use a bit of copper gasket spray that I had in the garage to ensure a good seal.
Good luck!
Old May 22, 2010 | 05:19 PM
Antmen's Avatar
Alas it worked out without having to remove the IM.
I appreciate the input.
Fired right up and never heard it sound so good.
-Anthony
GreenRoving
Jan 27, 2015 08:33 AM
Kalev
Mar 29, 2014 08:54 PM
Phifross
Aug 12, 2013 04:56 PM
bigsmokefarmer
May 13, 2012 12:35 PM
demonlarry
Aug 29, 2009 10:28 PM
