HOW THE F@#@$ Fuel Pump Retention Ring
How in the heck do you get this off.
It's a retention ring, correct? Lefty loosey?
Screw driver get on one of the indents and bang with a hammer.
Should be simple!!!!
Got it. Put some PB on it and let it sit. Finally came off.
So question putting in the pump. Put gasket in the hole first then insert the pump, or put gasket on pump then insert the whole assembly
It's a simple 1 hour job and well described in RAVE.
Take your pick of these vids.
https://www.google.fr/search?ei=7mBM....0.be-W7t4jvlo
Many have done this exact error before you many times. Soak the ring for 24 hours in penetrating oil and then use a large very BLUNT cold chisel or even the special tool to remove the ring. Use copper grease to install the new ring and also a new gasket. Don't over tighten the ring as it's not necessary, the gasket does the work, follow the RAVE torque recommendation.
I gave up on getting mine back on. Mangled it getting it off and could not get it on correctly. I have a tennis ball under the metal access lid keeping tension on till I can find a better solution. I feel your pain. The retention ring is a piece of crap.
