How to flush brake fluid
Old Sep 2, 2009 | 10:16 AM
  #21
jycsalas's Avatar
Originally Posted by just_dw
I have a logistical question, as I've never done this procedure before. Do you need to close (put the cap back on) the resevoir after every time you add fluid during this job? I'm assuming not, as long as you don't let it go dry, correct?
Make sure you clean the cap and reservoir so that nothing gets inside and contaminate the fluid.
Old Sep 2, 2009 | 11:34 AM
  #22
antichrist's Avatar
Not required, but if you're doing it outdoors, at least drape a clean rag over it so stuff isn't blown in by the wind.
Old Sep 2, 2009 | 09:39 PM
  #23
demonlarry's Avatar
http://www.speedbleeder.com/
we use them on bikes...
they are on my wife's GTI, all of our hydraulic braked Vespas, and they are going on the Disco.
Old Sep 3, 2009 | 06:48 AM
  #24
antichrist's Avatar
I put a set of those on one of my Land Rovers back in the 70's. A little while in VT winters and the they turned to lumps of rust. Looks like they now have stainless steel ones. So $60 for one vehicle. Cheaper to get a Motive Power pressure bleeder.
http://store.motiveproducts.com/shar...unt2=305137276
Old Sep 14, 2009 | 07:13 AM
  #25
usedcar129's Avatar
4th Gear
Thanks Spike,
This is very useful information to flush the brake fluid.It can be very helpful to stop the bleeding of brake fluid.
used autos for sale
Old Sep 23, 2009 | 11:53 PM
  #26
jerseymike68's Avatar
Nice information
________
RacingGirl
Old Nov 28, 2009 | 09:59 PM
  #27
Baylink's Avatar
Default One important point
made in the RAVE, but which no one has mentioned here: they want you to bleed them in a *specific order* -- presumably, shortest to longest pipe run.
That order, for LHD cars, is RF, LF, RR, LR (and I've checked that 3 times to make sure I didn't mistype it; it's on page 70-31).
On further reflection, it's probably *not* shortest pipe run; the brake machinery on an LHD is on the left firewall and fender wall. Hmmm...
Old Nov 29, 2009 | 09:41 AM
  #28
SDinDS's Avatar
Depending on how old and rusty the caliper is, you may have to use an 11mm line wrench on the bleeder screw. i almost rounded them off using a box wrench.
Eric
Old Feb 21, 2011 | 12:48 PM
  #29
jpluncford21's Avatar
This may be a stupid question, but....I just replaced the calipers on my 04 and was wondering if I needed to flush all the lines or just the front drivers and passengers
Old Feb 21, 2011 | 02:29 PM
  #30
Alex J's Avatar
I was just going to post this. When I was looking through there it stood out to me that they work front to back which is opposite from 99% of the other cars on the road.
