How to flush brake fluid
Old Feb 23, 2011 | 04:12 PM
  #31
Cal's Avatar
Cal
7th Gear
Default You might also consider a Mighty-Vac . . .
Hand-operated vacuum pump. I bought one of these years ago for flushing the brakes and clutch master cylinders on my Gold Wings, I think I paid $25 for the kit.
Well worth it for a one-man show!
Old Mar 11, 2011 | 02:07 PM
  #32
RAYMAN975's Avatar
Originally Posted by Disco Mike
No, the lid can stay off. Pump out the old fluid first, add new DOT 4 fluid and bleed it the old fashion way with one person pumping the brakes and the other bleeding.
are you saying pump them all out dry, then fill the resevoir and bleed-refill-bleed-refill etc?
or suck most of the fluid out of the resevoir, but not bone dry, so no air gets into the system? and then bleed from there?
Old Mar 11, 2011 | 02:34 PM
  #33
Bundu's Avatar
Banned
Do not pump dry, you do not want to get air in there. Remove most of the fluid from the reservoir without letting air in, then fill it, bleed one wheel and fill up again, then bleed the next wheel.
Old Mar 11, 2011 | 03:06 PM
  #34
RAYMAN975's Avatar
thats what i figured, just wanted to make sure. i have bled brakes before, but never flushed any
Old Mar 11, 2011 | 03:26 PM
  #35
Bundu's Avatar
Banned
Flushed = bleed until new brake fluid comes through.
Old Mar 12, 2011 | 03:23 PM
  #36
texmbr's Avatar
Start at passenger rear, then driver rear, then passenger front, then drivers side front as you bleed.
Old Mar 12, 2011 | 09:27 PM
  #37
jafir's Avatar
I'm too lazy to go pop the hood and look, but is the opening on the reservoir perfectly round? If so, you should be able to just sit the whole bottle of brake fluid upside down in the opening, and it won't leak. Then you won't have to keep filling it after each wheel. If you are really good you won't even spill much when removing it. Just make sure to clean up any if you do spill it...
Old Mar 13, 2011 | 07:27 AM
  #38
Bundu's Avatar
Banned
The opening is round.
Old Mar 25, 2011 | 06:31 PM
  #39
Dublindisco's Avatar
According to the rave manual on a right hand drive truck its
1. Front left passenger wheel
2. Front right drivers wheel
3. Rear left passenger wheel
4. rear right passenger wheel.
Old Feb 20, 2012 | 03:45 PM
  #40
EricTyrrell's Avatar
What are you guys doing with your old fluid?
