How hard is adding ACE?
Roaming with friends, off topic, sights and sounds...all other parts of the forum.
You are the one who isn't listening/reading.
The original engine braking comment was what you should do if your brakes fail (assuming one is stupid enough to drive with no/weak brakes).
However, you should always use engine braking when descending mountains.
To the original poster.... if you are looking for ACE and 7 seater....
How about looking for a HSE model which comes with the ACE.... and then add the rear 3rd row seats? It would be easier to find a SE or HSE with ACE.
I was looking for months for a SE7 or HSE7 in good condition. I ended up buying a 2003 SE. I am currently adding the rear seats, seat belts and trim from parts which I procured from a salvage yard. Total cost was $200 for the seats + $350 for the rest of the anchor parts, headrests, seat belts and trim. This would be a cheaper and easier modification than retrofitting ACE .
Eamon
brunettc
Audio/Visual Electronics
Aug 8, 2005 07:31 AM
