How long to bleed
Vacuum bleeders suck (pun intended).
If you have the blender open too far they will suck in air around the bleeder. I prefer pressure bleeders like the motive, but you risk blowing the seals from the master to reservoir.
Try tightening the bleeder just a little. Or maybe temporarily wrap it with Teflon tape. Just don't block the hole.
Is there any reason to think my issue is air in the modulator since all I did was change the brake lines?
OK, Wen't old school on it and I think i got it. Got the Mrs. to help out. Now I have to hear her complain that her legs hurt.
Actuator:
4 lines go into top. Starting with the Line closes to the front of the vehicle, I call this line 1.
Pump 5 times and hold brake down. Release Line 1 and tighten line 1. Release brake.
Pump 5 times and hold brake down. Release Line 2 and tighten line 2. Release brake.
Pump 5 times and hold brake down. Release Line 3 and tighten line 3. Release brake.
Pump 5 times and hold brake down. Release Line 4 and tighten line 4. Release brake.
Top off brake fluid.
Move to the calipers
Caliper bleeding steps:
Right/Rear Pump 5 time and hold brake down, Release bleeder, tighten bleeder. Pump 5 times and hold brake down, Release bleeder, tighten bleeder. Repeat till you don't see air coming out.
Top off brake fluid
Repeat caliper bleeding steps on Left/Rear
Top off brake fluid
Repeat caliper bleeding step on Right/Front
Top off brake fluid
Repeat caliper bleeding step on Left/Front.
Repeat the Caliper bleeding steps until the first two pumps don't get any firmer.
DONE!
Actuator:
Top off brake fluid
Top off brake fluid
Top off brake fluid
DONE!
audiS4S6
04-18-2010 11:02 PM
flyingalexf68
05-09-2006 01:51 PM
