How long is normal for the oil light to stay on after cold start?
Old Oct 19, 2022 | 01:17 PM
nickm347's Avatar
Default How long is normal for the oil light to stay on after cold start?
2001 Discovery with 197k miles
I replaced the oil pump about 65k miles ago
The last oil change was about 2500 miles ago with Shell Rotella 15W40 & WIX Filter
When the Discovery has been sitting, the oil light stays on for about 2.5 seconds after cold start. I don't remember it ever staying on that long, it used to go out immediately.
There are no other symptoms, ambient air temperature doesn't seem to make a difference.
The light does not come back on or flicker/blink.
I just noticed this the other day and haven't had a chance to check the PSI or change the oil/filter.
How long do oil pumps usually last?
Is 2.5 seconds indicative of some sort of problem, or normal for the mileage?
Old Oct 19, 2022 | 02:14 PM
greisinb's Avatar
2.5 seconds seems long but is probably OK (especially with modern engine oils). But for what it's worth I have the same oil, filter, and mileage and my oil light goes out right away, faster than my more modern vehicles actually. I would keep an eye on it though, like everything else with a D2
Old Oct 19, 2022 | 05:36 PM
Brandon318's Avatar
This is not normal. Doesn't necessarily mean it's something catastrophic, it's just not supposed to be on that long. It should go out right away.
Old Oct 19, 2022 | 06:18 PM
nashvegas's Avatar
Agree, mine goes out immediately. Maybe takes 1-2 sec after an oil change if that. Time to plumb in an oil pressure gauge.
dealbergaria11
Jan 12, 2021 10:49 AM
drewski
May 31, 2013 10:50 AM
Marnold-98-Disco
Feb 2, 2012 08:57 PM
JeffKrav
Sep 19, 2011 06:09 PM
jasonrusso
Apr 18, 2011 09:17 AM
