How to lube tailgate hinges?
Old Sep 7, 2020 | 12:20 PM
Tony Luna's Avatar
Default How to lube tailgate hinges?
Is it possible?
Old Sep 7, 2020 | 12:35 PM
Dave03S's Avatar
The most important thing to keep lubed there is the pin with the catch strap at the bottom of the door... And of course the inner part of the handle. I haven't needed to lube the actual hinges...
Old Sep 7, 2020 | 06:07 PM
Extinct's Avatar
I am partial to Maxima chain wax because it goes on very thin and migrates in all the little cracks and then after a few minutes the solvent flashes off and it dries completely non tacky so that if you accidentally touch it later it doesn't get on you and it won't attract dust and dirt
Old Sep 7, 2020 | 10:35 PM
nashvegas's Avatar
I use boeshield T-9 on the rear door hinges (and all the hinges)
Amazon Amazon
Highly highly recommend. You can read about it. I spray on the rear hinge with it open with a microfiber behind it, open and close a few times, repeat 2x. Seems to work well.
BTW I found out about this stuff at recommendation of pebble beach concours judge re: vintage aluminum bodied cars (literally)
Old Sep 8, 2020 | 08:50 AM
Sean Maginness's Avatar
https://www.amazon.com/BOESHIELD-Cor.../dp/B001447PEK
I use T-9 too. Been using it for years as bicycle chain lube and then on cars and motorcycles and around the house.
Old Sep 9, 2020 | 04:41 PM
Tony Luna's Avatar
Thanks for all the prompt and helpful responses, Just happen to have an old can of Boeshield T-9 from my cycling days - OLD can...
Gsfg
LR4
Mar 17, 2020 02:51 PM
Mrnyceguy78
Jan 9, 2020 12:32 PM
CollieRover
Aug 14, 2019 04:37 PM
PurpleRain
May 30, 2019 03:46 PM
RhinoRover
Nov 7, 2017 07:02 PM
