How many volts to start?
Went out and bought a voltage meter without ignition engaged or truck on I'm reading just about 6 volts or 18 dB's.
Typically how many volts are Disco 2's required to start, the battery starts up my VW with ease.
Had a bad harness for awhile that I've now fixed, have I booted my battery?
Thanks
Thanks
You need enough voltage and enough amps.
If you're reading 6v that's way too low. It's a 12v starter and you want your battery and connections to be in good shape that you get at least 12v to the starter. Even with the battery fully charged, too small cables, loose corroded connections will reduce the voltage to less than optimal, i.e. 12v.
if you are reading 6v's either the battery is utterly fried, or you arent getting a good connection on the terminals with the voltmeter. you need a meter capable of putting a load on the battery to test its charge level, a nearly dead battery can still show high 11v's, even low 12's and still not have enough amps in reserve to supply the current draw of the starter. you probably have several dead cells in the battery if you are only getting 6v but have a clean firm connection on the terminals using the voltmeter.
Yep, a load can be something as simple as switching on the head lights. Dead cells will take the meter to the basement under load. Takes some real amps to run the starter, a clamp on ampmeter on my D1 showed 285 amp draw cranking. Any little corrosion can have so much voltage drop that the starter won't work.
