How to mount D ring shackles on stock rear bumper?
Old Jul 8, 2015 | 08:25 AM
Freedom38's Avatar
Default How to mount D ring shackles on stock rear bumper?
Has anyone ever done this before? I think it would be nice to have some good recovery points in the rear. I was thinking drilling through the plastic cover and somehow mount them to the reinforcement part.
Old Jul 8, 2015 | 08:27 AM
ZGPhoto's Avatar
Do not do that. If you want to have a recovery point on the rear you need to attach it to the chassis at the minimum. Ideally a hitch mounted shackle adapter.
Old Jul 8, 2015 | 09:07 AM
Paul Grant's Avatar
The "reinforcement part" is just more plastic.
Get one of these:
SHACKLE MNT 2" RECEIVER w/HITCH PIN, RNA1022 - Rovers North - Classic Land Rover Parts
It will fit in your tow hitch.
Old Jul 8, 2015 | 03:25 PM
mln01's Avatar
I have always just planned to do as pictured in the case of a recovery from the rear; one end of my tree strap inserted in the receiver with a hitch pin holding it in place and the other end connected via shackle to another vehicle.. Or some variation on the theme. Is this a bad idea?
Attached Thumbnails How to mount D ring shackles on stock rear bumper?-image-4108487827.jpg
Old Jul 8, 2015 | 11:12 PM
antichrist's Avatar
Well, have you ever tried to remove a bent hitch pin? It's not particularly easy.
And you don't want to use a non-elastic strap (which a tree strap is) in that kind of recovery.
Old Jul 8, 2015 | 11:51 PM
Shiftonthefly1's Avatar
Maybe you can weld a jeep bumper on with angle iron.
Old Jul 9, 2015 | 12:07 AM
Racer X's Avatar
Originally Posted by shiftonthefly1
maybe you can weld a jeep bumper on with angle iron. :d
shots fired.
Old Jul 9, 2015 | 12:09 AM
Racer X's Avatar
Get one of these:
This.
Even the ****ty Harbor Freight version (that I own, don't judge me...) is a better bet than D rings in the stock bumper.
Old Jul 9, 2015 | 08:10 AM
mln01's Avatar
Okay, fair point re: the hitch pin. Would the largest possible diameter Grade 8 bolt holding the loop of a proper kinetic recovery strap be okay? Not surprisingly I'm not keen to drop $50 on a shackle mount if a $3 Grade 8 bolt will serve the same purpose with no compromise of performance.
But back to the hitch pin; why would we be concerned it will bend with a strap attached to it and not be concerned about it bending if holding a shackle mount? I expect the answer is that the load is distributed across the full width of the receiver with the shackle mount but may be more concentrated with a strap. Is that correct?
Old Jul 9, 2015 | 09:08 AM
Racer X's Avatar
No, that will bend too.
Seriously man, if you half *** this, you're going to break ****. And if $50 isn't your speed, $10 should be.
D-Ring Receiver Hitch
