How much ATF do I need for a fluid/filter change
Guys-
When changing my 04 D2 transmission fluid and filter (every 30k miles) how much ATF do I need to get the job done? Seems like last time I bought more than my shop used.
Thank you.
Thank you.
More than a gallon. When I did my transmission maintenance I got three one gallon jugs, because I did a flush (replace fluid only, drive around block, drain, then replace filter). I also added a bottle of Lucas for final refill.
The AB video is really helpful not that I'll be doing that job myself as I don't have a lift. If I supply 2 gallons of ATF then that should more than work. Thank you for the insights!
