How much "binding" is normal on sharp turn/parking
OK, So I have owned a couple RR's but this is my first Disco. I bought it super cheap as it needed a trans and front prop shaft (2 guesses as to why hahaa
). Well, my question is how much binding is normal? My father's full time 4wd Jeep Grand Cherokee can sharply turn into parking spaces without the tires barking but this Disco doesn't seem to like the sharp turns.
Just to let you know. I have been driving it for a month now with no issues at all (except I can't get the rear door/tailgate open, not stuck handles..guessing bum actuator). Also, 4wd low works just fine. I am averaging about 16mpg. 3 amigos are on. Center Diff Lock light is on as well...tried doing the quarter turn on the 10mm CDL lock to lock out the front but never could get it to work, or turn the light off for that matter.
Any ideas?
). Well, my question is how much binding is normal? My father's full time 4wd Jeep Grand Cherokee can sharply turn into parking spaces without the tires barking but this Disco doesn't seem to like the sharp turns.Just to let you know. I have been driving it for a month now with no issues at all (except I can't get the rear door/tailgate open, not stuck handles..guessing bum actuator). Also, 4wd low works just fine. I am averaging about 16mpg. 3 amigos are on. Center Diff Lock light is on as well...tried doing the quarter turn on the 10mm CDL lock to lock out the front but never could get it to work, or turn the light off for that matter.
Any ideas?
i locked out my cdl when i was waiting for my driveshaft to come in and i had all those lights as well.
they all went away once the new shaft was in and the 10mm was clicked back.
(ps. it was way easier to unlock/find the cdl with the shaft out still..might not be helpful now, but a suggestion)
Thank you all for the information but I am a little confused. My 00 Disco is full time 4wd and 4wd High and Low seem to function as they should. Doesn't locking the CDL just lock out the front diff? Maybe I am confused. My transfer case just happens to have the CDL bolt on top but it is not hooked up to anything. I just want to know how much binding is normal with full time 4wd.
Thanks!
Thanks!
Thanks!
Thanks!
Again, NO BINDING IS NORMAL. Your truck is NOT full time 4 wheel drive until you unlock the CDL. This has NOTHING to do with whether you are in high or low range.
With the CDL locked, it is "part time 4 wheel drive", to be used only on loose ground. What you are doing is just the same as driving around in a 4 wheel drive pickup with the front hubs locked and in 4 wheel high. If you keep driving like that without unlocking the CDL you _WILL_ break things, just the same as you will break things running around in a pickup in 4 wheel high. The binding is your big hint that you are putting stress on the driveline.
With the CDL unlocked, the transfer case can send the appropriate amount of power to the fron and read axles (rather than a straight 50/50 split) and it will no longer bind. Please do yourself a favor and do some research on full time versus part time 4 wheel drive and what a center differential is.
tibyABv6
Dec 18, 2012 10:09 PM
Mountain Goat
May 23, 2012 12:28 PM
ncrover1994
Feb 20, 2012 07:43 PM
IanWhitefeather
Nov 13, 2010 05:45 PM
